I'm using the original charger and for two days the battery only takes a charge up to 3 percent. I find it funny that the battery on a tablet that is less then 2 yrs old would die just before it is paid off. What can I do other than dump it?
You could buy a new battery, for the Ellipsis 7 they're in the $20 range online
mvelasco9, we truly understand how important it is to make sure your tablet is charging correctly especially with it being less than 2 years old. Please allow us to further investigate the details. Can you please let us know if there is any physical damage to your tablet and or charger (loose bent, broken, corrosion or liquid damage)? Also, does your tablet have the latest software update?
SylviaT_VZW
Follow us on Twitter @VZWSupportIf my response answered your question please click the �Correct Answer� button under my response. This ensures others can benefit from our conversation. Thanks in advance for your help with this!!
