Ring volume slide does not work on moto droid. Phone does not ring for incoming calls. I go to Settings, then Sound, Ring Volume has a slide to increase volume, but it does not slide. How do I fix this?
The ringer is definitely an important feature on your phone, LIONHORSEMAN. I'm sorry it's not working. However, I'm eager to get this resolved.
Can you tell me what exact Moto Droid phone you have? How long have you had it? Also, has it been dropped or wet at all? Please elaborate to better assist you.
VanessaS_VZW
Thank you for your “rapid” response. Due to the delay in response, I obtained the answer elsewhere.
Sent from Mail for Windows 10
LIONHORSEMAN wrote:Thank you for your “rapid” response. Due to the delay in response, I obtained the answer elsewhere.Sent from Mail for Windows 10
LIONHORSEMAN wrote:
This is primarily a customer-to-customer forum; a response by a VzW rep isn't guaranteed and when they do respond, as you noted, it's usually a few days after a thread is left.
