I am trying to bring over my Samsung S7 Edge from Boost Mobile. The device has been unlocked by Boost and was used on a Boost Prepaid account. I plan on using the device on the monthly unlimited plan at Verizon. When I enter the IMEI number I get the message that the device is not compatible on Verizon's Network. Can I found out why the device is not compatible, is there anything that I can do to make it compatible?
Thanks in advance for any suggestions.
