Hi all,
There is a very annoying and unacceptable problem with the newer FIOS HD DVR model - the Motorola 7216-1. When you fast-forward or rewind HD broadcasts or HD recordings, the actual playback position is 30 seconds or more away from the place that you visually pause on. For example, say you are watching a live or recorded HD tennis match and you press FF or Rewind to see a particular shot again. You press pause when you get to the beginning of the shot. You then press play. With the 7216 DVR, the playback resumes some 30 seconds away from the point you paused at, making it extremely difficult to precisely play back stuff.
I have reproduced this problem with two separate brand new 7216 boxes. It does not appear to be a problem with the older 6416-2 model and it doesn't seem to occur with non-HD broadcasts or recordings. If you have the 7216-1 HD DVR, try it yourself with a HD broadcast or recording and if it happens, please post a reply to this message thread to help better alert the FIOS technical folks.
I have notified technical support by phone and they said they would forward this problem on. Apparently, there are other issues plaguing the 7216-1 HD DVR as well.
