This past Tuesday I installed the new N router. Also, we upgraded to FiOS Quantum 75/35 (previously 15/5). That was activated the following day. I can't complain about the internet speed to our pc since it's wired. Speed tests showed we were getting what was advertised. ๐
For the wifi, I can't figured out for the life of me what's causing our devices (e.g., our Nexus 7 tablets) to have a link speeds of 65Mbps one minute and then drop down to 5 or even 1. The same situation was happening with my HTC Incredible II phone, but I think that connection was tapping out at 54Mbps. The bottom would just drop out of the signal for some reason. Other times we couldn't even connect back in. The devices would say they're not in range even when they were in front of the router. Not sure if I fubarred the router install or what? I just swapped out the current Fios router for this new one. Pretty straightforward. At first, I logged into the router software with the defaults, but then I changed the the username, pswd, SSID, etc. to match what I used previously. I thought it was working fine the night of the install but not so much after Fios got bumped up in speed the following day. Maybe just a co-inky-dink?
I know you never get the same speeds compared to a wired pc but this seems worse (wifi-wise) than before the new router came along. I've read that the 'N' routers can be finicky to set-up to run properly. Maybe a setting or two is off?
I don't know if the fact that my son's netbook's wifi card is only b/g compatible would slow our network down? At this point I'm grasping at straws! I talked with tech support last night for 40 mins to no avail. I got the usual story about wireless devices running slower than wired ones, that these smaller devices aren't capable to maintaining higher speeds (which I'm not sure I agree with 100%), the more active devices you have slows down your network, etc, etc. I get all that. But something is going on or actually, it's not. LOL!
Why I don't agree with the above statement I mentioned is because I have my tablet at work now and the wifi speed is 54Mbps and it's constant. So it seems to have no problems with this speed, unlike what I was told over the phone.
Let me know if I can provide any further technical details that'll make it easier to help diagnose our wifi issues.
Thanks for listening to me whine
-bill
