We live in Northern VA and got FIOS in mid-April, an upgrade from antenna TV & 1990's DSL. We have had constant problems with sound on WETA HD (channel 526). As new subscribers, we received Cisco STBs.
I have identified at least two other people on this forum with a similar problem on the same channel and others who have reported audio or other problems with the Cisco DVR STBs. At least one person on this forum reported solvng the problem by getting his Cisco STBs replaced with Motorola boxes.
Our specific problems are:
1. Sound frequently missing when tuning to 526 (WETA HD). Sound is fine on the non-HD channel. Can sometime be restored by bouncing back and forth to other channels several times. The sound is fine on the non-DVR box in the house.
2. Sound missing from some recordings on that channel.
What we've done to fix it:
1. Replaced the DVR STB
2. Replaced old RG-59 cable that fed boxes with RG-6. Technician checked signal strength and it was OK.
3. Reset boxes several times
4. Swapped the two boxes in the house - problem stayed with DVR STB. (For the record, one TV is HD and uses HDMI, the other is an old analog CRT using composite video & L/R audio feed)
5. Was told of a reported problem that was resolved by pressing the "pause" button - that did not work.
Verizon tech says they've referred this to video engineering for troubleshooting but I have not heard anything since then (two days). Since they seem to be treating this as an isolated problem I'd like to see if it is or if others have similar problems that might alert Verizon to the breadth of the problem and/or to other details that might help them in their diagnostics.
If we're the only people with the problem maybe a third DVR STB might solve it. If enough people report the problem here, maybe our combined report might get it resolved. As we're getting down to the 30 day full return limit I'd like to make a decision quickly.
Thank you for your help and responses.
