All,
I'm trying to navigate through a jumble of wires. I'm not a techie. How do I set up fios with my audio receiver, PS-3 and tv? What settings/menus do i need to play with on my tv? Any help much appreciated!
OYE! - Have you though of having Best Buy send out the Geek Squad?
You have said nothing about what kind of a TV service you are attempting to hook up to, as well as what kind of audio you want to have hooked up. How did you get your internet to work?
Get the make, model, of each piece of equipment, and go to the manufacturer's web site, and download the manual for your reference. Get the same data from your TV service provider. Check back when you have them and have decided what you want to do---if you aren't a troll!
