I cannot connect my new Panasonic Viera TV (TC-P55ST50) via WIFI to my FIOS MI424WR router.
It works with NO security turned on, but will not connect with WEP turned on (which I want for security).
I have triple checked I am entering the password correctly (even changed it and re-entered it) and no luck.
Any suggestions?
Is this a TV issue?
A FIOS router issue?
I have also tried to manually enter the WIFI settings in the TV menus, but to no luck there either:
IP address
Subnet mask
Default gateway
DNS
