When connected via wire I run the Verizon Speed Test and get 85Mbps download 38Mbps upload speeds.
When connected via wireless (to the Actiontec MI424WR Rev. I router) I run the Verizon Speed Test and get 20.5Mbps download 19Mbps upload speeds.
- I have downloaded and run the VzSpeedOptimizer100.exe program... after rebooting, Speed Test results were the same.
- Based on one forum post I read... I've tried setting my wireless channel to 11, then to 6, then to 1... with increasingly worse Speed Test results.
- Based on another forum post I read... I tried to change my encryption from WEP to WPA2, and my wireless internet stopped working altogether.
- Another posts suggests that the router is garbage (which I'm starting to believe) and just buy another wireless router and use it instead.
Is there anything I can do to get the speed up to the levels I'm paying for without buying another router?
It sucks that I'm paying for a super fast plan and not getting any of the benefits of it.
Thanks in advance for any help you can give.
