I have two xbox, one 360 and the other one xbox one, the 360 is wireless, the xbox one is wired connected, the xbox one always starts with moderate and when both consoles are on at the same time, the xbox one acts very slow. I need someone to tell me which way will be best to set this up network wise, i want the ports to be distributed to both xbox when they are connected. If the 360 is on first then it takes over the udp 3074 port and the xbox one can no longer use it. One post here said to create a different distribution of ip's under the my network then connect one of the xbox on the other network, for example create one to go from 1 - 125 and i just picked 140 and add the ports by forwarding them to the 140, but when i try doing that it tells me that the wireless one, which is using ip in between 1 -125 is already using it. any help please, i appreciated.
