After spending hours on the phone with FIOS Technical "Experts" (sic), the experts say it is IMPOSSIBLE for the Actiontec MI424WR Rev I router is that it periodically defaults to a DNS Server allocating IP addresses of 10.168.1.X
The funny thing is that I have had wired PCs, wireless laptops, Wireless tablets and cell phones getting allocated IP addresses of 10.168.1.X
Silly me for fixing my problem before I could get the "EXPERTS" to look at it and verify it because it is MY fault or something I am doing that is causing the problem. I must be changing the settings to 10.168.1.1 for the gateway.
By futzing around with your and THEIR router, you can get the IP addresses to be correct. At worse case, you put in a static IP address of 192.168.1.X for your PC, laptop or other device and you'll work around the problem.
There is a firmware issue with the router that periodic ally crops up for some unknown reason and Verizon can not comprehend technical issues so they sluff it off as operator or YOUR issue when in fact it is their issue. Actiontec does not know about it since they refuse to talk to Verizon clients and Verizon Tech support is clueless so the problem does not get resolved.
My cell phone presently has an IP address of 10.168.1.101 which Verizon Tech Support extraordinaire says is impossible to get. I have a tech coming out here tomorrow to see the impossible.
I am waiting with baited breath to see what excuse this guy will give me but I suspect he will be sympathetic since he is in the field and NOT reading from a script.
Wish me luck.
George
