Seems to be impossible to get in touch with someone via customer service line. Can I be pointed in correct direction to begin the process of getting a pole moved?
Hi aaronmtbh,Your issue has been escalated to a Verizon agent. Please check your Private Messenger Inbox for a message from a Verizon Support agent. You can find your Inbox by clicking on your username at the top right corner of this page and then clicking the envelope icon that appears at the top of the menu. Response times may vary. Please continue to check your Inbox for a reply from a Verizon agent. Please direct all correspondence concerning your issue to the agents who will be assisting you privately.
