Hi,
I checked the website for the wiring diagram for the DVD player installation, but there is no info on installing a DVD player. Can somone direct me to a link on the Verizon website where I can find the diagram? Thanks for your help!!!
What are you trying to do?
You can't play a DVD through the VMS as it does not have an operational input.
You have to connect the VMS to one input of the TV and the DVD player to another.
