I have a standard defination set top box that will reboot at times when I turn it on. It doesn't matter if I use the remote that came with the box, the remote on my phone or the power button on the front.
Once it reboots and reload everything works fine. This is not the first box that has done this. I have had three and each of them has done it in the past. The last set top box died and I got a replacement. The second time I powered the replacement up, it rebooted on me. I do have the power outlet set to be on and off with the box. I don't know if that makes a difference.
I had Verizon tech staff check out the old one and reflash it, but that didn't help. So I'm wondering if others have had the same problem with a SD box and if so what did you do to get it to work?
Thanks.
