I have a Verizon TV/Internet bundle.
I use my own router for the internet and have a MoCA adapter to connect the TV Box.
This does work and the TV box is fine...but then the MoCA adapter will randomly turn itself off at a random time.
The power light goes out on the MoCA adapter and the TV Box says it isn't getting a signal.
The coax light also goes out on the MoCA adapter. Sometimes it's both, sometimes it's one or the other.
It takes several power cycles and replugging to fix it. I literally JUST got it powered back on and less than 24hrs later the power light is out again and the TV Box says it doesn't have a signal.
I have no clue what the issue is, I just want my TV to have a consistent signal.
It really shouldn't be this hard to have a TV signal...
Current setup is ethernet to the MoCA adapter. The Coax from MoCA to the TV Box in the other room. Am I missing a vital piece or something?
