Why can't I receive notification of incoming calls via email AND block certain incoming calls at the same time?
If one is on, and I try to activate the other, I get an alert like:
You have requested to turn the Call Notification Always feature On, but currently the Incoming Call Block - Reject Calls from Certain Numbers feature is turned On. You may not have these two services On at the same time. Do you want to: Turn Call Notification Always On and turn Incoming Call Block - Reject Calls from Certain Numbers Off?
