Hi, I do not know what to do.
When I switched to werizon DSL internet the first two months the internet was OK, but after the light for the internet on my modem- westell 7500 started to turn red, and some times just off color. Initially the switch off/on helped but after some time the internet was not available in the most of the time. I called several times to the technical support but after hours, talking and switching...the problem stayed the same. In the end, we decided to replace the modem, BUT here after 1 week the internet is again almost not available. I tried to connect with another modem (from friend with werizon internet modem (the model is westell 6100F) and after few minutes the light for the internet turned off. I do not know what it can be?! If it helpful, we have home phone connected with werizon that works well.
Can any body help?
Thanks.
