Been having terrible speed and intermittent connection issues. Modem takes several minutes (if at all) to sync with DSLAM.
Outside at the NID I recorded these numbers from my modem...
Line Attenuation Downstream was 54.9 dB, Upstream was 31.5 dB
Noise Margin Downstream was 25.1dB, Upstream was 20.0 dB
Inside wall jack connection numbers were within 1dB of the numbers at the NID.
Could the line attenuation be my issue? If so, how do I get someone to fix it?
