I have a Mini 311 - 1037NR laptop from HP with a Verizon Wireless card installed. It is running VZAccess Manager.
When you boot up the computer everything works fine, it loads up VZAccess Manager, and connects to the internet. However if the internet isn't used for an extended period of time VZAccess Manager seems to disconnect from the Mobile Boadband.
Under the Available Network, option it lists Verizon Wireless - VZAccess Connected, but on the Usage Screen it brings up the message "This program cannot display the webpage" and the connection switches to dormant. Furthermore I cannot use any internet related devices.
Once this happens I have tried
Disconnecting the red button marked Disconnect WWAN then Connect WWAN
Detecting the Device
Closing out every program I have been using (Including VZAccess Manager) and restarting everything,
None of these obvious solutions seems to work
In fact the only thing which consistently works is restarting windows. Not even logging off seems to work.
Any fix would be appreciated. We use this laptop as a mobile cash register, and if we are not at a busy event, going for a half an hour between transactions is not uncommon. Having to reboot is inconvenient.
