I started to have problems on Tuesday.
My Equipment is:
Dell Precision 870 PC with a Intel Pro network card
Apple IMAC with the Apple Lan connection
Lynksys/Cisco E3000 (Problem started with a Linksys WRT610N router)
Verizon (Actiontec) GT701C DSL modem
I came down to my office and I noticed that the DSL light on my modem was not lit. In the past
this has ment that there is a problem in the Central Office. Later in the day I got hold of Verizon
tech support and we got the DSL running again with the modem connected to either computer.
When I connect the router to the modem and the computers to the router, Dell via wire and Apple
via wireless 5.0 GHz 802.11N inout and restart both the router and the modem, I get connectivity
through the router and the modem but the DSL light on the modem is not lit. After a long period
of time the DSL light may come on then I loose connectivity.
Everything was working correctly til late Monday night/early Tuesday morning.
I have reset both the modem and routers to factory defaults several time. I have a problem when
trying to get connectivity with the moden after setting it up again and it takes me to the Verizon
DSL startup site. Tech support walked me throuogh using the "192.168.1.1/verizon/redirect" and
shutting the redirect off. I then have connectivity as long as the router is not connected.
I thoought the router went so I just installed a new router, the Linksys/Cisco E3000, and I still
have the DSL light problem.
