I recently purchased the Home Phone Connect unit from Verizon. It consists of a device for residential phone service. The instruction book shows simple connections....power and phone cable only. It was connected as shown in the manual, and all lights are on....MESSAGE LIGHT: BLINKING, POWER LIGHT: ON, BATTERY LIGHT: CHARGED , and TWO SIGNAL LEVEL LIGHTS: ON (indicating a strong signel). When I try to make a call....I immediately get a busy signal. i cannot receive any calls....(incoming calls go immediately to messages (thats why the message light in always blinking). I've talked to Verizon technicians twice....but not results. One Technician said that i do not need the power cable connected....only the phone cable. (while this does not make sense, I tried it and of course, I didn't even get a dial tone). Another technician suggested that I dial "1" before each number.....again no change.
Has anyone had troubles getting their Home PHone Connect system to work..... I would appreciate any help.
Thanks in advance.
lcdrdan
