This has been an issue for my DSL recently. I would say around 6 months now, before that the DSL didn't have any problem at all.
- Everytime, it's rain regardless heavy or not and there is wind. I start to loose connection. My modem keeps restarting
- After the modem restarted, myDSL speed slowed down significant. Also, noise margin dropped, line attenuation is increase
- And the restarting modem, kept on like every 5-10mins interval.Until the weather was back normal (sunny and no wind)
- I talked with Verizon technician once on Monday this week when the same situation happened. I had the speed fix, but it happened again since yesterday.
here is my transceiver static when it's normal weather
| Transceiver Information | Down Stream Path | Up Stream Path |
| DSL Speed (Kbits/Sec) | 3358 | 863 |
| Margin (dB) | 27.3 | 17.7 |
| Line Attenuation (dB) | 25.5 | 11.3 |
This is today transceiver static after the rain yesterday.
| DSL Speed (Kbits/Sec) | 2444 | 271 |
| Margin (dB) | 6.1 | 9.8 |
| Line Attenuation (dB) | 36.5 | 19.8 |
Sometimes, the speed even dropped down to 1.1Mbps or lower
So, it kind unstable speed I have when the weather is bad.
my phone line from the NID box to phone jack is CAT-3
my questions are :
- so does my line has problem ? Or is it Verizon control system or something?
- If it is my line problem, do I need to replace my phone line ?
- If I need to replace my phone line, how can I do it? Call Verizon ?
If there is any information that is helpful to solve my problem, please let me know. Appreciate all your answers
