Last time it took me 2 hours of begging on the phone to finally get a tier 3 tech to reset my dsl connection to 3mbps after a bad filter caused repeated drop outs. I'm in the same spot again, my dlink router shows my connection speed down to 2.1 after a lightning storm blew a line filter, when before my speed was 3.4. There's got to be an easier way to get reset, it only took the tech about 30 seconds to do it!
All I'm looking for is an easier way to get my connection reset!!
If it helps I have a verizon dlink 2750b, I don't think it will give transever stats, but here is my traceroute.
news.giganews.com
traceroute to 71.116.**.*** (71.116.**.***), 30 hops max, 60 byte packets
1 gw1-g-vlan201.dca.giganews.com (216.196.98.4) 0 ms 0 ms 0 ms
2 216-166-96-117.fwd.datafoundry.com (216.166.96.117) 0 ms 216-166-96-101.fwd.datafoundry.com (216.166.96.101) 0 ms 216-166-96-121.fwd.datafoundry.com (216.166.96.121) 0 ms
3 ash-b1-link.telia.net (62.115.42.153) 102 ms 102 ms 102 ms
4 ash-b2-link.telia.net (213.155.137.223) 0 ms 0 ms 0 ms
5 TenGigE0-0-0-10.GW1.IAD8.ALTER.NET (152.179.50.233) 16 ms 16 ms 8 ms
6 as0-0.PITT2-CORE-RTR2.verizon-gni.net (130.81.20.95) 18 ms 23 ms 23 ms
7 A9-0-1715.ERIEPA-DSL-01.verizon-gni.net (130.81.194.75) 23 ms 29 ms 30 ms
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * Max number of unresponsive hops reached (firewall or filter?)
