Step one: Visit http://www.giganews.com/line_info.html and post up the Traceroute the page shows, if you wish. Be aware that your non-bogan public IP Address will show up. It might shown up as the final hop (bottom-most line of the trace) might contain a hop with your IP address in it. Either remove that line or show only the first two octets. What I'm looking for is a line that mentions "ERX" in it's name towards the end. If for some reason the trace does not complete (two lines full of Stars), keep the trace route intact.For example this what I saw when I was using Verizon
news.giganews.com traceroute to 71.242.*.* (71.242.*.*), 30 hops max, 60 byte packets 1 gw1-g-vlan201.dca.giganews.com (216.196.98.4) 13 ms 13 ms 13 ms 2 ash-bb1-link.telia.net (213.248.70.241) 39 ms 7 ms 7 ms 3 TenGigE0-2-0-0.GW1.IAD8.ALTER.NET (63.125.125.41) 4 ms 4 ms GigabitEthernet2-0-0.GW8.IAD8.ALTER.NET (63.65.76.189) 4 ms 4 so-7-1-0-0.PHIL-CORE-RTR1.verizon-gni.net (130.81.20.137) 6 ms 6 ms 6 ms 5 P3-0-0.PHIL-DSL-RTR11.verizon-gni.net (130.81.13.170) 6 ms 6 ms 6 ms 6 static-71-242-*-*.phlapa.east.verizon.net (71.242.*.*) 32 ms 32 ms 33 ms
Step two: Do you have any other DSL modem besides that D-Link?
If so, Can you provide the Transceiver Statistics from your modem?#3 If you don't know how to get that info:a) What is the brand and model of your modem?b) If you have a RJ-45 WAN port router connected to it: What is the brand and model of the RJ-45 WAN port router?#4 If you have a RJ-45 WAN port router connected to the modem, even if you know how to get the Transceiver Statistics from the modem: What is the brand and model of the RJ-45 WAN port router?
If you do not have any other DSL modem besides that D-Link, as where the transceiver Statistics are located in the DLink 2750:
To my knowledge, no one has managed to find and report the location of the transceiver Statistics page on the D-Liink modem, so we'll need Verizon to grab the stats from the DSLAM, and while they're at it, check the logs on their end to see if the line is dropping out physucally, or is dropping out on another sense.
{please keep it relevant} They put optimizers on the equipment outside and it is slowing the speed down and we are not getting what we are paying for. 3mb plans are getting 1.24mb/sec. **bleep** poor if you ask me. I will be coming around the neighbor hood today to get your input on how we should proceed!!!
