I recently purchased (6/10/11) the Verizon Wireles MiFi 4510L due to the need for multiple wireless device access to the internet.
I previously had the Pantech USB Modem UML290 modem for my laptop.
The most glaring concerns that I have with the Mifi device are as follow(s):
1. Dormancy...the signal goes into dormant status anywhere from 3 seconds to 1 minute, even when I am transmitting wirelessly from my laptop to the Mifi device. Unlike the USB modem, I would lose access to the server long enough to produce time out messages, etc on my web pages. The same applies to my client e-mail servers.
2. Drop-outs. Periodically I will notice that my Windows connection will switch from "Connected" to "Connected with Limited Connectivity" to "Local Only" during a session. The Windows taskbar gui icon will show periods where no upload or download of data is ongoing, even during an active and sustained download (example: software update).
3. My connection speeds for download are running around a maximum of 0.5 mb/s...but average around 0.25 mb/s...with upload speeds the same or 1/2 that amount. This is about 1/2 to 1/3 the routine speeds I had with the UML 290 USB Modem. Both connection speeds are far less than I experienced with my Sierra Wireless PC5750 card...which I dearly loved, but would not work with the upcoming 4g LTE network.
Background Info>
I use Lenovo T400 with embedded wireless antenna and Intel Wifi Link 5300 AGN Wireless Adapter and use Windows Vista SP2 with the latest software updates and drivers.
I have excellent signal strength with both the Mifi and USB modem. I am in a 3G coverage area right now....still waiting on 4G. My dbm values for 3G with the Mifi have been running between -71 and -80.
I have reviewed several posts on the problems mentioned above, but there does not seem to be any good answer from Verizon as to how to "work-around" these issues. I would sure love some guidance before my return period for the Mifi runs out in less than 2 weeks.
