This is extremely annoying! All calls go directly to voicemail. I only know if someone called if I check my call log, or they leave a Voice Mail message.
I don't have Google Voice. My phone is not set to silence mode. These are the most common reasons that I have found on the internet to this problem.
I have turned off the phone and removed the battery out multiple times. What is causing this and how can I fix the problem. I'm on version 2.2.2 and there are no needed updates to apply.
Thanks,
Tracie
