Found 2 problems with Razr, one is the menu buttons on bottom dont stay lit unless it is dark in room or you cover light sensor that is no good and other is when using speech if it makes mistake and especially on last word when you back space it erases everything you wrote, never had that problem on Revolution or Fascinate. Any thoughts to these problems? Thanks
