I purchased my HTC DROID Incredible 2 new from a Verizon store about 10 months ago. I've had few problems with the battery or with charging. I have noticed that gradually it's been holding less and less of a charge, but assumed it was normal with increased app usage and the ageing of the battery. But recently, it's started shutting down completely, despite having just been charged-- at first it would only shut down while I was operating it-- whether opening an app or sending a text message-- and after a few days it started shutting down even when it wasn't in use. When I plug it in, it does appear to be charging, and generally works well whilst plugged in, but as soon as I unplug it, it shuts down, and even upon re-starting, it will continue to turn off. In the few seconds that it's on in between, the battery icon shows a low battery, even though it's just been charged for hours. I haven't downloaded any new apps or software recently-- the last download was several weeks before this started to happen. I've tried gently cleaning the battery sensors and charging port, but nothing has worked. Any suggestions would be appreciated!
