For the past few weeks, once or twice a week at least, I've been having the following problem with my LG VL600 device. I may be connected for part of the day with no problem, and then all of a sudden my connection stops working. If I unplug the device, close the VZ Access Manager software, then reinsert the device and reopen the software, the 4G seems to connect, but shows only transmitted data (TX), and ZERO received data (RX). I get a valid IP address, but cannot ping the default gateway. The first time I called support, the tech was able to reset something on their end, and it started working again. The 2nd time, they sent me into the Verizon store to get a new SIM card, but when I got there, the connection was working again.
When the issue occurs, I also receive an error message when the VZAccess Manager software tries to check my usage:
"Your usage request did not complete. Please try again later. Error WMC1003"
I should also mention that I'm seeing 2-3 bars typically of 4G service, and I'm in downtown Brooklyn, NY.
Anyone else having this problem?
Thanks!
