I have tried to look at my pics and when I pull them up I get "No Activity found"...I took SD card and still does not work???
Please help!
Jennifer what actually did you do with the SD Card ? be specific how did you remove it from your phone..
I dismounted the card and then opened side
Ok did you shut your phone down prior to removing the Card. And removing the card isn't really necessary all that you'd have to do is Tap your settings go to Storage >> then go to Un-mount Card>> Un-mount it and then Remount it that can sometime stir or Refresh the Card with out loosing your Pictures or Data Now since you took the Card out of the phone Go ahead and re-insert it !!! if the phone is ON Shut it OFF and re-insert the Card as i explained once that is done Turn the phone on & let if fully power up and go threw it's sequences.. Then go to your Picture Gallery and see if they'er there... Let me know what ya Find..
