Hi,
I updated to KitKat (4.4.2) a few days ago on my Samsung Galaxy S3. Since then my battery hasn't lasted nearly as long as it used to. The stock battery monitor (under Settings) shows 'Android System' is consuming way more battery life this ever used to. Upwards of 25% - 45% at any given moment I check. It's now the top battery drain when the Screen used to be.
Things I've done:
1) Leave the battery out for a few minutes
2) Wipe the system cache partitiion
3) Factory reset (several times)
4) A combination of 1,2 & 3.
I've also done a factory reset and left the phone alone (no extra apps, airplane mode, no use) and the Android System still consumes all kinds of battery life. This looks like a OS-level bug.
