Both WIFI and Bluetooth cannot now be activated on my DROID MAXX. No problems at all until the recent update, so I can only assume that this issue results from the update. At either the WIFI screen or at the Bluetooth screen, the window is empty except the slider, and when the slider is moved from OFF to ON, it hangs there about five seconds then slips back to OFF. Rebooting does make one difference: the first time you open the WIFI screen several options in a menu do appear in the window below the slider as expected, but after the first attempt to slide it to ON and then it returns to OFF, the options disappear and the window is again empty (except for the impotent slider). Is there a fix?
