Add me to the list with major dissapointment after upgrading to Kit Kat 4.4.2. My phone used to go 15 hours and still have at least 70% left. Now I have 70% after 5 hours.
Anyone have nay ideas on how to get better battery life? I have blue tooth turned off, but need to have wifi on. I don't have email syncing except when I check it, and don't go on facebook or the internet.
Hello ffbob561! Let's get going on this so you have more battery life! Have you checked in the settings to see what is using the most battery? Do you have Power Save mode enabled?ChristinaB_VZWVZW SupportFollow us on Twitter @VZWSupport
Screen is using 42%. All other items are less than 11%. I do not have power saver enabled.
Hi again ffbob561! Thanks for the update! Please enable power saver mode and monitor the device to see if that makes a difference. Please also make sure you back out of your applications.Thank you, ChristinaB_VZWVZW SupportFollow us on Twitter @VZWSupport
