My HTC Droid Incdreble 2 LTE 4G is running very slow and the battery is running down very quickly. Just installed a new battery and still does the same thing. Any ideas? Thanks!
I'm sorry your battery is not working properly and your phone is running slow nd2638. Does your phone have the latest software? Are you having an issue with any of your apps? If so, uninstall them because problematic apps can cause functionality issues with your phone because they may not be compatible with the software. Also ensure you clear the browser history on your phone periodically. Keep us posted.KinquanaH_VZWFollow us on Twitter @vzwsupport
I'm having the same problem with my HTC Incredible 4G LTE, nothing has been changed no new apps. I was wondering if you had figured out your problem.
