My BBZ10 won't turn on after battery died? Help?
reebok6453, let's bring life back to that device! Connect that device to your charger for at least 30 minutes and then press/hold the power button down. Keep us posted. LasinaH_VZWFollow us on Twitter @VZWSupport
Did you plug it into your charger to charge it after it died? If not I would try doing that and it should turn back on.
