I turned on VoLTE (Advanced Calling) and have noticed that the call volume over LTE is greatly reduced compared to a "regular" phone call. Even with the volume on max it can be very difficult to hear. Is there a fix for this?
monvoix,I'm glad to hear your volume works well on other calls but we want it to work great with Advanced Calling as well! Can we try turning Advanced Calling off and then back on? http://vz.to/14IQhEv Or reset network settings? http://vz.to/14IQuat AndrewT_VZWFollow us on Twitter @VZWSupport
monvoix,Being able to hear when on a call is absolutely important! What make/model phone do you have? When did this start happening? Please provide some additional information. Thanks!ErinW_VZWFollow us on Twitter @VZWSupport
I have the iPhone 6. I just turned on Advanced Calling a couple days ago. There just seems to be a major difference between the volume of the call over LTE vs. a traditional call. If I turn off VoLTE the volume is fine.
No difference in VoLTE call volume notes in our 6 and 6 plus. I have not seen this reported on this forums before. Not sure what would be going on in your case.
Turning it off and back on seems to have corrected the problem. Thanks!
