Hi
At home with wi-fi, incoming calls ring on my iphone 6 and my wife's iphone 6. This does not happen outside the house. Is this something with the Advanced 1 LTE that Verizon has?
Thx for the reply. Yes, my wife and I both have the same apple sign-on. I found out thru the apple support site that we could disable mobile calls in the FaceTime settings and achieve the same result.
Let's make sure you get the right calls on the right phone, planemech! This is a recent feature added with iOS 8 and the iPhone 6. It does not have to do with Advanced Calling as it is caused by having the same Apple ID on each phone. iPhone 6 now has its own support for calls via WiFi. You will want to go to Settings and adjust the log in under Messages, iCloud and iTunes.Thank you,YaleK_VZW Follow us on Twitter @VZWsupport
