Got the Android system update pushed to my phone last night. These are the issues I am having now:
1. Major battery drain - I can literally watch the battery draining over the course of several minutes. No background apps running, either. Within 10 minutes, I have gone from 33% to 28%.
2. Fitbit and Garmin will not sync unless I turn on location services. Both of these devices should be syncing throughout the day and are done over bluetooth. I should not need to turn on my location in order for this to happen.
3. None of my Amazon Prime Offline playlists will play now. I keep getting an error stating "Something wen wrong trying to play this song from your SD card." I don't believe the card is going bad, since I can view and manipulate files and play other music files from the card through the Music app. The only way I can now listen to my Amazon playlists is to stream them through the cloud, which is obviously not going to happen.
These are all apps I use multiple times daily with no problems until the system update pushed last night. All of these apps are kept up to date. I can't undo the update to bring back the functionality, but I can't exist without these apps functioning properly.
Are there any solutions or are there some new settings that need to be activated?
