Re: 4G LTE outage??
voh88
Temple Hills, MD. Service has been out for me since last night. No 4G, 3G, 1X, or anything. I'm currently doing a factory reset to correct a problem with my phone but because it can't connect, I'm stuck waiting for activation. Verizon, if your service is down, you need to let your customers know. Put a notice on your forums or website or something.
I've been panicking for the past few hours. After visiting my local Verizon shop, I only then learned that the network was down.
Re: 4G LTE outage??
ElevenBravo
Don't bother. Just confirmed network outage in NE, and Midwest. Supposed to be resolved by 1700 today. 9March2013
Re: 4G LTE outage??
JD_Racer_Dad
We are back up in the Layhill/Silver Spring area, hope it stays that way.
Re: 4G LTE outage??
ustressed
We are having problems in the Hampton Roads area of Virginia too with 4G access.
Re: 4G LTE outage??
varonec
I'm glad its not just me - in Chesapeake/Hickory pix messaging hasn't worked all day,,,,,
Re: 4G LTE outage??
voh88
Any word yet? Its around 7 and my service is still down.
Re: 4G LTE outage??
ElevenBravo
Annandale, VA - Mine came back and has been steady since about 1645EST.
Re: 4G LTE outage??
TechSupportMachine
These possible outages are not posted online. I recommend calling tech support (800-922-0204 option 3) and asking them to check alerts and tickets in your zip code. Keep in mind, unless multiple people in your area are reporting the exact same issue, it is most likely related to something else. If it is a network-related issue, this advice should get you fixed quickly.
