Connectivity Issues
BillRogers
Well, for what it is worth, the 4G site near me just started providing a signal you can connect to.  I'm using a USB 551L by the way.  At first, the 4G would connect for about 8-10 minutes, then disconnect and reconnect again.  I went into the device manager and found that all the com ports associated with the device were set at 9600.  I moved them to a faster setting...seems to have helped.  Let me know what you find.
