***Announcement: Welcome to the new Verizon Community! We have merged our Wireless and Fios Communities to bring you the best place to discuss any Verizon product or service, along with all things tech! We have many new features to discuss with you in the coming weeks, but first we want to make sure that all of you who have been active on either of our communities before are able to log in! For many of you, we have been able to merge your Wireless and Fios community accounts so all of your Community contributions are all in one place. If you were active in both communities and you previously used the same My Verizon account to log into both, you’re all set! You will be able to use those same credentials to access the new Community. If one of those accounts was with My Verizon and the other was a Community Member Only account, please use your My Verizon account to log in. Please note that we were only able to merge those accounts that were attributed to the same email address. If you only had one account on either Community, you can log into that account exactly as you have before. For some of our Fios Community members, you may have an issue logging in. If you had an account on the Fios Community and you’re having login issues, please use the Community Member Only login page and use the “Forgot my info” link to reset your password. Once you complete this, you should be able to log in normally. If you continue to have any further issues logging in, please email us at verizon.community.team@verizon.com and we’ll assist you to get you back in the Community! Keep an eye on the Community announcements - we can’t wait to show you what’s in store. The Verizon Community Team
Droid 4G LTE data throttle for unlimited plans?
HomeCookN
A couple of months ago I upgraded my old phone to a Razor Maxx, but kept my original unlimited data plan. Until a few days ago, I was getting really great download rates, 15,000 - 20,000 kbps. but in the last few days, the max speeds have fallen to 200 - 500 kbps, maybe a 95% decrease. I'm not a big user, never more than 5 Gigs per month.
What might be going on, guys? Any ideas or advice?
Re: Droid 4G LTE data throttle for unlimited plans?
Tidbits
Legend
Could be network congestion or tower problems. When I was testing out my usage to the extreme I was getting full speed and I ended up using 40GB that month(my average is 2.5GB).
HomeCookN
Thanks a lot for your info; doesn't sound as though they are holding me back intentionally in your opinion. On the other hand, it's only my download speeds that are slow: my upload speeds are still blazing. If the cause were as you suggest, wouldn't that also reduce my throughput in both directions?
Via 4G LTE DROID, as if you care
Tidbits
Legend
Not always. I won't go into much detail about it. May take forever to explain. However it may not be the network and may be your devices radio or software. Have you tried to see if there is a data saving setting? It might sip on download bandwidth. I am not too familiar with your device.
HomeCookN
Thanks for the fast response, Tidbits! I’ll look into a data saving setting on my phone. I can also tell you that when I’m using Wi-Fi, the download speeds return to their previous fast rate. Thanks a lot for your help. Off to work.
HomeCookN, those were great speeds you were receiving and want to help get you back to those speeds. Are you still having issues with your data speeds? There is no network optimization on 4G LTE devices, so we would need to troubleshoot your device and check for any issues in your area. What city and state are you located in? Does your device still show 4G when your speeds are this slow? Do you notice this happening at a specific time?
MarquiaF_VZW
HomeCookN
Thank you very much for this follow-up! Actually, within 48 hours of my previous email to you, something happened somewhere because all at once the download speeds became blazing fast again, even faster than before. Now I’m consistently seeing speeds between 5-15 Mbps. I did change one thing on my end: between the time I sent you the first email and the return of the great speeds, I turned the phone off and restarted it. Do you think that could have made the difference?
4ktvs
I had the same data speed issue with a droid razr. This could have just been a one time thing.
I think it did make a difference and you should reboot the phone every now and then by off and then on again. Just about any phone will have issue's after being "up" for so long. Yes even the iphone and WP7 will too.
Hope this helps.
