You can't turn Advanced LTE on or off. -- Why do you want to?
I suspect RMCCAMMAN is referring to Advanced Calling and HD Voice. You can turn that off, but that is not what Advanced LTE is
- Advanced Calling is using LTE to carry voice data using IP protocols, I.e, VoIP
- HD Voice is part of Advanced Calling that allows higher fidelity voice when both phone are compatible
- Advanced LTE is carrier aggregation. This allows the phone to use different frequencies at the same time to get faster data speeds. For example, if you have a Verizon signal on band 13 and band 4 your phone will be able to use both at once -- aggregate them into one fast incoming data stream.
You can't shut it off.........
I'm able to turn it off in My Verizon app.
@weth thank you for the clarification and I just learned something!
Can you send me how you did that on your app?
Thanks
Due to the age of this thread, it will be locked in order to keep discussions current. If you have the same or a similar question/issue we invite you to start a new thread on the topic.
