Hey everybody I live in catlett va and there is no LTE where i'm at will there ever be LTE here.. My LTE starts when i get to warrenton
>>Personal information removed<<
Message was edited by: Verizon Moderator
Hi Kevinis309,
I just check the coverage map to show we have the 4G coverage in Catlett, VA. However, what's your zip code where you use service? Which device do you use? Here's a link to show the coverage http://tiny.cc/qdbj3w. You can use the map to enter your zip code to show the type of coverage where you're specifically located.
Thanks,
EdW_VZW
I use a iphone 5 and the zip code is 20119 i have lte exstended will i exer have strong lte...i have a lifeproof case on my phone will the case block the signal?
