We have both iphone and Netgear VZW MiFi - and get 3-4 bars.
Download speed is 15-20 MB, but upload is 200-300k.
This just started in the past 2 weeks, before that we had 2 MB of upload speed
We are in Winslow Arkansas and our only means of internet
Cant find anywhere to report slow internet speeds
NetGear Mifi shows RSRP of -92 dbm and SNR is 16 with 4 bars on mifi.
Hello Ppotter 402,
I know how important it is to have a great connection. I have reviewed the location you are in (http://www.verizonwireless.com/landingpages/better-matters/#maps ) and I do see several areas with no service or 3G coverage. Is this area hilly or forested? What service are you using to test your speeds? When did this first begin?
ChristopherM_VZW
Hello Ppotter 402,
ChristopherM_VZW
Hi there Christopher
We have excellent cell coverage, and you can see we have RSRP of -92 dbm and 3-4 bars, so I don’t believe it is a coverage issue
Also, it has been working good since January and just slowed down 2 weeks ago.
I did call into customer support and they opened a NRB case on this and it appears to have been corrected, as now I am back to getting 2 MB upload speeds again.
Thanks
Paul
Thanks for the update ppotter402. I am glad to hear everything has been corrected and your speeds are back to normal. Is there anything else we can help with today?
Thank You,
MichelleS_VZW
Nope
Thanks for checking on us
