MiFi 4510L will not connect to my FTP
ja1111
Enthusiast - Level 2
Until yesterday, I used the Pantech UM175 USB modem and a Verizon 3G data plan. I "upgraded" to 4G and the MiFi 4510L MiFi device, and now cannot connect to my website for upload/download through any of my FTP programs. With the UM175, I never had any issues...didn't have to do any configuration or special setup. It connected every time, and worked flawlessly. However, the new 4G device, though working okay on all other online applications, simply will not connect to my FTP. I've used my regular web program, which contains an FTP client. And I downloaded two other programs (FreeFTP & SmartFTP) and could not get an FTP connection with either program. However, if I log off the MiFi 4510L and log on to my home network or any of several neighbors' networks, I have no problems logging into my FTP. I spent about an hour on the phone with Verizon Tech Support this morning. The fellow I talked to was very patient and really tried to solve my problem, but couldn't help. I went into the config program and tried Port Forwarding and a couple other options, but to no avail.
Has anyone else had this problem...and maybe a solution?
Thanks.
ja1111
Regarding my own message of about an hour ago...I started digging around in my FTP program and found a setting named "Use Passive Mode". Thought I'd try it and see what happened...IT WORKED! I can now log on to my FTP with my MiFi device.
In the documentation for my FTP program it states regarding "passive mode", "You may need this option if the FTP server is protected by a firewall".
ja1111
kiheiman
I have using a 4510L for the past few days and have noticed a few quirks.  The device works good as a wifi hotspot.  I have two Web cams on the unit.  However, I need to access the 4510 from the Internet to see live video from the cameras.  The port forwarding does not seem to work.  I have tried using the HTTP Web Browser port and the Telnet port.  I can never connect.  The main reason that I went with the 4510 feature was because of the port forwarding feature.  The port forwarding worked fine on the same two cameras behind a Linksys wireless router going to a non-Verizon Internet provider.
Has anyone else got the port forwarding feature to work?
Not applicable
Ja1111, thanks for posting how you resolved this issue!
ja1111
Thanks for the great service I always get from everyone at Verizon!
And I do not want anyone to think that the Verizon Tech Support team had given up on helping me with this issue. I had spoken to a gentleman named Edgar in El Paso, who had spent about 45 minutes on the phone with me dealing with this, and really exhausted every resource he had to try and help me solve the problem. He even called me back about an hour later, after researching the problem further and was ready to take the problem directly to Novatel...but fortunately I had stumbled upon the solution in the meantime and I let him know what it was.
This kind of service is why I have never used another provider...Verizon support is top-shelf!
deloswilbur
Enthusiast - Level 3
Ja1111 it's refreshing to see a positive opinion on here, I will be curious to see if that positive opinion carries through the next few months as you use the 4510L.
I hope you have better experience than I as I was the same way about Verizon until Decmeber, from that point to now I have become an embittered person that would happily pay the $175 and drop them tomorrow if there was any other option in the area I live.
As such to save you some frustration, if you should start running into problems with the 4510 I wil save you some searching.  When it starts to act up, if you are in a strong 4G area you may have to lock it to 3G if in the fringe global should be fine as it will try 4G then drop to 3G and stay there until it locks up.  It will lock up about 1-2 times per day.  The steps to fix are hold reset button in (not power but the reset button that you need a pin to push) until the display shows all icons, release, wait 1-2 minutes  and then hit the power button once to turn on.  Luckily for you the FTP is a constant connection so that one will stay steady if you are able to use 4G but any web browsing or sporadic connection will break every 5 - 20 minutes and that is only fixed by disconnecting and reconnecting.  You can try Verizon service for that problem but like the rest of us have gotten over the last 8 months the response will be "We know there are problems with the network, but the effort right now is on expanding the network and there are no resources available to work on existing problems"......yes, I am serious about that response......
Good luck
ja1111
Thanks for the tips...we'll see how it goes. I had one of the older 3G models that worked flawlessly. So far, no problems with the new one, but I travel extensively and it will be interesting to see how it performs as I move around the country.
deloswilbur
I had the MIFI 2200, that device was awesome.  It's the main reason I switched from the other USB 4G devices to the 4510L, however this one is night and day from the 2200, doesn't even seem like the same company made it.... Smiley Sad
mys
Hi, what's another wayof connecting to our MIFI? I have an HP XP Sp2. Tried to upgrade to SP 3 manytimes but it's saying the "expected software is not available in mysystem". Not what's the problem.  Please if anyone know any ideas on how I can solve this issue before I return this MIFI. Thanks so much.
John_Getzke
Champion - Level 1
Mys,
Your problem is unrelated to the original poster's problem.  I suggest you start a new thread so that more people will be able to review your problem and offer thier solutions.
cunninw
ja1111,
Can you please explain what your mifi configuration looks like?  I have tried everything and can't seem to get my FTP client to connect.  Like you it works fine on my home network.  Did you still have port forwarding turned on when you discovered the passive setting?  The passive setting did not work for me.  I am trying to connect through the dreamweaver cs3 ftp client.  Not sure if that helps?
I am a little confused because the following article claims that this cannot even be done:
http://www.4ginfo.com/index.php/verizon-4g-lte-doesnt-work-for-remote-applications.html
Any help would be greatly appreciated.
Neander
Contributor - Level 2
I can only offer a low-tech solution that works for my Pantech uml290.
I boot up the FTP program and try to connect before I boot up VZWAcess Manager & connect. Of course I get an error, but my theory is it snags the ports it needs, so that when I do connect, the modem grabs the unused ports.
This might be a lot of superstitious BS,  but it hasn't failed me yet.
BogieNMe
I am in the same situation as your client.  The Mifi 4510L will connect to internet just fine and will even connect to server but will not transmit any data.  I have spent (and this is not an exageration) 6 hours on the phone over this issue, 3 hours today alone.  I am in passive setting.  I have gone through Port Filtering and Port Forwarding and no luck.  The server technician insinuated that Verizon was now charging for FTP access, but Verizon says no.  HELP!!!
BogieNMe
Also, the Verizon tech personnel have been kind and helpful, but simply hapless.  They are only reading from the same manual that I am.  Bummer.
RockyC
This is driving me nuts! My 4510 was working pretty good late October in 3G, then our area got LTE and I was over- joyed with the speed. But now I can't update three websites I maintain without having to do a bunch of work arounds. I can't even access one site.
I live out in the boonies, so this was great, or so I thought.  I keep hoping for a fix. Until then I'll go in to town and update my sites at McDonalds. So much for convenience.
