After reviewing the coverage map for my home, I should have good LTE coverage near Annette Dr and Miller Rd in 63052. Both my wife and I have iPhones (5S & 6) which we cannot connect on outgoing calls and can't hold an incoming call for more than a minute. The 3G Data service is spotty at best and most often doesn't work.
Hello sikulas! Help has arrived. I regret to hear of the connection troubles you've been experiencing. When did this trouble begin? Are you having any trouble with text messages or data/internet service? Does service restore outdoors? Share details. Thanks!
KristieQ_VZW
We moved here about 10 months ago and it has been the same. The data is service is practically non-existent, regardless of indoors/outdoors. Essentially once you turn from the Outer Road onto Miller Rd, west, the service just drops.
Thanks for the additional information Justin. While we make every effort to provide you with LTE and the best wireless experience possible, some factors outside of our control may impact signal and it if normal for it to fluctuate. Your device is designed to connect to the strongest signal at all times and 3G may be stronger in some areas. Resetting network settings on your phones may improve your signal reception, please reset network settings and test: http://www.verizonwireless.com/support/iphone-6-reset/#reset-network-settings
AntonioC_VZW
