I have a Ticwris Max smartwatch. It is fantastic and I would like to get a sim card for it. I do not know if it is compatible with the network however. Here are the bands it works on.
The Ticwris does not have CDMA network connection, so it is not compatible with Verizon. You'll probably have to check with T-Mobile. Do you have the IMEI number to check it?
I have a Verizon sim in it and it works for 4G LTE, but if you get out of 4G LTE service it will not work with Verizon
That's a really good question, pittom69. It will likely still work; however, not being an actual Verizon device, it is not guaranteed to. Where will you be going, out of our coverage area? Out of the country?
VanessaS_VZW
