Using UML290 with 4G Router
Not applicable
Has anyone tried using their UML290 with a 4G router? You don't use VZAccess Manager with a router. I'm wondering if this would solve the problems everyone seems to be having. I know CradlePoint has a beta 4G firmware update for their MBR1000 router and one of their portable routers. One problem they evidently still have is the router cannot automatically switch back and forth between 3G and 4G. That would be a problem for the portable router driving down the highway in your car, of course. EDIT: Worse yet, the beta firmware won't work at all with 3G. http://moremobileinternet.com/verizon-4g-mobile-hotspot/
Re: Using UML290 with 4G Router
norfdungal
This sound like the same issue some folks are having with UML290 on a Mac. The posted solutions supposedly work when you are in a 4g area however they do not work when in 3g. Does anyone (verizon?) have any info on this? This modem is 4g/3g compatible correct?
mc1lean
See my post in response to '4G on the fringe'. I'm using a UML290 in a Nexaira BC2 and it rocks (coming from Sprint 3G anyway). I followed the tips on evdo forums, locked my modem to LTE and now working from home over VPN every day is much less painless (I occasionally drove in just to get a decent network, I don't see that much anymore - at least until the smartphones come out and people start trashing 'my' tower).
Re: Using UML290 with MBR1000 - Modem will not stay connected
RaymondM
I have an MBR1000 router from Cradlepoint and a UML290 modem from Verizon.  I have firmware 1.9 installed on the router.  I found out that when I use the 5 volt power supply that came with the router the UML290 modem will not stay connected to a 4G network.  If I use a 12 volt car type power source the modem does stay connected.
JerryF
Sr. Member
RaymondM,
You worried me a little so I looked.  My Cradlepoint MBR1000 came with a 12 volt 1.5 Amp output and 110 volt input power supply.  Try to get Cradlepoint to give you a new one.
JerryF
toughbook
Novice
That is intersting to hear about the power supply issue. I use the MBR-900 and will have to try this out.
