VERIZON - WHAT HAPPENED? - 4G LTE coverage is so poor!
regrets_with_verizon
VERIZON - WHAT HAPPENED? Last year and the year before, 4G LTE coverage was flawless. This year, I toggle between 3G and 4G LTE each day more times than I can count - in areas where I use to have no trouble connecting to 4G LTE. Please stop adding a ton of customers if your towers can't handle it. Starting to regret coming back to Verizon for their so-called unbeatable coverage
Tags (3)
Correct Answers
Re: VERIZON - WHAT HAPPENED? - 4G LTE coverage is so poor!
Regrets_with_verizon, I never want you to have any kind of regrets at all with coming back to the Verizon Wireless family. The area that you are in looks like it should have pretty good coverage. I would recommond on taking the device into a Corporate Store Location and getting the sim card replaced for free. You can always locate the nearest store location by following this link: http://www.verizonwireless.com/stores/ Also, please keep in mind this is a public forum. Please edit your post to remove any personal information from the post. Please keep us posted if you have any questions.
KevinR_VZW
Follow us on Twitter @VZWSupport If my response answered your question please click the �Correct Answer� button under my response. This ensures others can benefit from our conversation. Thanks in advance for your help with this!!
MiiHere
Leader
What is your Zip Code?
Verizon can't control what gets built around your area, or the area of the tower that may cause an interference with your service.
What phone do you have? Is it the phone you had when 4G was working well? When did you switch phones?
60126 zip code
I have an HTC one M7 and yes, it was the same phone I was using when I had
great service. I left Verizon to move to a cheaper carrier. Their network
strength was terrible so I came back to Verizon...only to discover, Verizon
has changed a lot..in a bad way.
Annie
Personal Information removed as required by Verizon Wireless Terms of Service
Message was edited by Verizon Moderator
MiiHere
Leader
Because you've had that phone for nearly 3 years, I suggest going to a Verizon corporate store and getting a free SIM card replacement. If you're suddenly having trouble connecting, that could be the cause. The SIM card is how you connect to the network.
sprmankalel
Leader
You should try switching your Preferred Network to LTE/CDMA if it is set to Global.
Thank you, I read that from an earlier post and tried that. Same results
though.
Annie
KevinR_VZW
Thanks I'll try an obtain new SIM.
MiiHere
Leader
What a great idea...if only someone had suggested it sooner. (:
I'm actually just trying to close this question so that I can try the SIM card idea.. i thought by marking a answer correct it would close the topic..but I was wrong. Thanks for suggestion the SIM thing also from the get-go. Hopefully this resolves my issue.
