Is it possible to get my European Samsung Note 4 Quadband to work with Verizon? It has GSM Quadband that doesn't work I just found out about that. But is also has WCDMA and LTE so why won't my Verizon card work in it?
Oh verizon if I had known, I would be an at&t user ...
No. It doesn't have the proper radio frequencies compatible with the Verizon Wireless network.
WCDMA is different from CDMA. Also the frequencies don't match up for LTE.
The technologies (LTE) AND the frequencies must match. Verizon uses band 13 primarily and band 4 Second. Band 13 is a must.
Additionally all all phones need to support Verizon's CDMA frequencies.
